Nový Firmware pro K10D
1.10 Firmware can be downloaded from here:
http://www.4shared.com/dir/1796154/f4cc ... aring.html
Více na Dpreview... Kdo to zkusí??
K10D firmware 1.10
Mohu ujistit, že se jedná o skutečné firmware Pentax. Naistaloval jsem do své K10D (i když se mi svíral zadek)... Všechno je jak má být a co obsahuje dukumentace
Ano, zatím není na oficiální WEB Pentax (na přiložené dokumentaci je "date release 23/1/2007, tedy kdy bude "oficiálně k dispozici), ale na dpreview už to má spoustu lidí stažené a nainstalované, jsou nadšeni..... také jsem stáhl na trochu jiném link:
http://www.4shared.com/file/9096751/9934950f
Firmware Version 1.10 for K10D obnáší tyto změny:
The following function has been added in version 1.10
① Wireless control of external flash through built-in flash.
How to set
・Press Fn button and four way controller key ( )
・Flash mode selecting screen display
・Select Wireless mode
・ Flash discharge method can select by [ Flash in Wireless Mode] in the custom menu
1 ON Built in flash works with master
discharge
2 OFF Built in flash works with controller
discharge
・ HS(High speed sync)in not available
・ Select SLAVE 1 in Wireless slave mode when use
AF540FGZ or AF360FGZ
How to use: Same as using two external flash, refer to the operating manual
② Instantly return to centre AF point by one push of button in AF select mode.
[Center of AF Point] is added to the AF function
In the custom menu
When AF point switching dial set to “SELECT”,
AF point is set to Center
③ Possible to change ISO setting by dial at TV/AV mode.
④ ISO setting change by dial while the ISO setting is being displayed on the LCD by pushing OK button.
・ ISO setting is being displayed in the view finder and on the LCD panel when setting the P/Tv
Av/M/B/X mode and then ISO can change by turning e-dial.
・ Possible to change to AF ISO by pressing green button in P/Tv/Av mode.
⑤ Green button function in M mode is available at TAv mode (Hyper manual).
・ Tv/Av value can set automatically when press green
button in TAv mode.
With this change, the name of [Green button in M] change
to [Green button in TAv & M] in the custom function
⑥ AV and TV switch by dial at P mode.
The item No.2 is added to the [e-dial in Program] in Custom menu.
With this change, Av can change by front dial and Tv can change by rear dial.
⑦ Instant return to the default value by green button at strobe light compensation.
Amount of flash compensation return to the initial value (0.0) by pressing green button when display flash mode screen.
+ The following contents have been corrected.
1. In rare case, vertical stripe at long time exposure.
2. Released “B exposure” and show battery empty sign when using B mode.
Dodatek z 20.1.2006:
File už není na této WEB k dispozici !!!!!!
How to set
discharge
discharge
In the custom menu
button in TAv mode.
Naposledy upravil(a) jir_ist dne 20 led 2007, 14:37, celkem upraveno 1 x.
jir_ist
Petře, pravda, byl to risk, ale tak 50/50.... věc se má tak, že dva lidé byli s K10D v servisu a oni jim tam hned nalili tohle nové firmware 1.10, tak se to provalilo.... Pentax asi nejdříve zásobil své servisy, pochopitelně... a někdo z některého servisu je asi členem dpreview Pentax forum a smiloval se a dal file k dispozici...
Další verze je, že někdo z Pentax se podílí na tom foru a firma se řídí názory "pentaxáků", že tedy udělala verzi "Beta" s vědomím, že to tihle lidé odzkouší než bude firmware "oficiálně" a případně ještě dále upraví.....
Nicméně, pracuje to bez jediného problému, ale každý ať jedná podle svého úsudku a odvahy, je to přece jenom dost peněz za kameru
... věřím, že 23/1 se objeví na WEB Pentax, nebo ještě poopraví podle reakce na tu Beta a bude to ver. 1.11 či 1.20 atp.....
V každém případě firmware pochází od Pentaxu, to je jisté....
jir_ist
kajfik
Nahoře máš vypsáno co firmware řeší...... z toho co píšeš jenom banding... JPG nepovažují za "neostré", je to co chtěli, bohatá textura a nepřeostřené v krajích, ať si každý může doostřit jak chce, naopak to nejde, chtěli charakter filmu (film like).... rozsah ISO se také pochopitelně nezměnil, není proč, je dostatečně široký......
jir_ist
Firm
Ok. Dík. Jen s tím rozsahem iso bych to tak neviděl... Tobě možná stačí. Někdo kdo chce fotit koncert....
...nebo divadlo... No a když chci fotit vodu na dlouhý čas tak s iso 50 a horsim svetlem si myslim to taky jde. ...chci rict bez nutnosti ND...
Neříkám že je umysl z iso 3200 vyfoceneho v divadle nebo na tom koncerte delat nejakou mega zvetseninu ale i kdyby jen pro web... Proste nemyslim ze by to bylo neco prevratne zbytecneho. Koneckoncu to maji i aparaty se srovnatelnym sumem a v posledni dobe jeste vetsi spousta kompaktu s..... Ale to je jinde...
Tak jo dik za odpoved a mej se. Jeste by to chtelo zjistit jestli sigma do budoucna pocita s HSM i pro Pentax. Bez HSM perspektivy bych v tom pripade do Pentaxe asi nesel.... Ackoliv kdyz nad tim posledni dobou uvazuju tak pro me foceni bych si pro zacatek stejne predstavoval: setak a tele 70-300 od sigmy + muj velky sen smc 70 / 2,4 ltd. Ale do budoucna by to stejne chtelo mit jistotu ze az budou penize a fotografovani me chytne bude moznost kvalitnich objektivu s HSM.
1) K10D má přece SR což ti umožní udržet v ruce o 2 clony víc, takže jsi na tom ještě lépe při ISO 1600 o 1 clonu, než bys byl při 3200 bez SR !!!
2) Není nic lehčího, než si dát ISO 1600 s expozicí - 1 (a máš 3200) a potom při zpracování RAW to vyrovnat + 1 !!!
Odborníci na CCD říkají, že je vlastně u CCD jedna nominální citlivost (ISO) a ostatní jsou vlastně podexponování či přeexpozice a vyrovnání v software kamery, proto je třeba zrno ve vyšších ISO .... CCD má určitý "rozsah_pružnost" která zachová ještě jistou kvalitu obrazu.... všimni si, že *ist DS a K100 atp. mají rozsah 200-3200 ISO a u K10D to posunuli na 100-1600 ISO, ale pořád je to 5 "steps"....
jir_ist
konečně oficiální
Oficiální firmware 1.10 pro K10D je na:
konečně je u nich 23/1 (jsou s časem pozadu)
http://www.pentaximaging.com/customer_c ... Id=8793673
(PDF file příručka se jim nějak nepovedla, čtěte níže....)
a tady:
http://www.pentax.co.jp/english/support ... gital.html
a tady je HTML s vyobrazením a popisem změn v Menu atd.:
http://www.digital.pentax.co.jp/ja/info ... 23e-1.html
a tady:
Naposledy upravil(a) jir_ist dne 23 led 2007, 10:29, celkem upraveno 2 x.
jir_ist
Cimrmanek
No tam pisou ze jen v M a TAv modu...? Ja pouzivam skoro furt Av mod a tam ma jednu super fci, ktera ale fungovala i s firmware 1.0, a to ze ti vynuluje kompenzaci expozice, coz se mi hodne libi
No ale kazdopadne ted uz myslim to ovladani vyladili temer k dokonalosti, snad jedina vec kterou bych jeste zmenil je aby talcitko RAW prepinalo obracene do JPG, kdyz se foti do RAW, jinak se jim to vsechno hoooooodne povedlo
green button
Green Button má teď nové funkce ve všech programech, nejen v M a Tv modu..... zapni kameru, měň mod programů a čti z LCD co můžeš s čím dělat (objeví se ti tam na 3 vt. či 10vt. podle nastavení) celková informace při přepnutí..... v Av mode je to třeba ISO Auto, jinde P SHIFT (co jsi si nastavil v Menu tj. přednost clony či času atd) ..... to tam dřív nebylo.... bylo tam ----
jir_ist
Zdravim kolegov pentaxakov! Este som nikdy neinstaloval novy firmware do fotaku. Nenasli by ste si prosim Vas niekto cas a nenapisali sem na tuto stranku zrozumitelny postup aj pre menej PC zdatnych uzivatelov ako nainstalovat z internetu do K10 verziu 1.10? Dakujem za pochopenie a budem velmi vdacny ak si najde niekto cas a odpise.
sixi
